Does a lower STR also mean a converter is tighter?
The basic question: Does a lower STR indicate a converter is fairly tight?
Thanks for any input.
Ed
STR the step up to The SS3200 will give you that great feel at low speed and will make you
when you push the the throttle down.You have made a very good choice for your car with the mod's you have listed in you posts
The STR is the extra leverage that you get from a dead stop take off
it is most usefull when powerbraking or jack rabbit starts, that is where you will get the max number 2.1 to 2.2
The looseness or tightness feel of a TC is imparted by the angle of the internal fins which also determins stall speed.
