PPM on a TH400
Old Oct 20, 2005 | 12:11 PM
02' hawk's Avatar
Default PPM on a TH400
Does anyone know the pulse per minute on a TH400??????? I need this to reset the speedomoter on my car. Any help is helpful!
Old Nov 14, 2005 | 11:22 AM
02' hawk's Avatar
You guys suck!!!!!!!!!!!
Old Nov 14, 2005 | 11:46 AM
Bryan @ Speed Inc.'s Avatar
haha... that's funny. what are you asking? i didn't think speedometers worked w/ 400 transmissions...
Old Nov 14, 2005 | 04:05 PM
jarediocamaro's Avatar
mine doesnt! maybe i should try hooking up that speedometer cable...
Old Nov 14, 2005 | 05:03 PM
cablebandit's Avatar
be careful with those tables...one is at like 4000 i think...if you change it, it will crash your pcm. been there done that..verified with hp tuner techs
Old Dec 2, 2005 | 07:28 PM
02' hawk's Avatar
How will that crash the pcm? How will i get the speedometer to work correctly?
Old Dec 3, 2005 | 12:08 AM
BigBake's Avatar
More info is needed from your end. What transmission does your PCM currently use T56 or the 4L60E? If it is the 4L60E file then you have no adjustments to make to your tune. If it is a T56 file, then you multiply the pulse by 2.5. You may have to add a little or take away a little to get it perfect but it will put you within 5mph. The crash he is speaking of is a bug in HPtuners, it sometimes causes a crash of the program in the middle of reloading your PCM, if you modify that pulse signal.
Old Dec 3, 2005 | 12:11 AM
BigBake's Avatar
Here is a link to a thread discussing that issue and how to get around it.
https://ls1tech.com/forums/showthrea...&highlight=VSS
Old Dec 5, 2005 | 09:00 PM
02' hawk's Avatar
Its a 4L60E car. The speedometer is reading about 20mph at about 5mph. I have a guy doing a tune for me and we don't know what the ppm is to get the speedometer to read right.
