HELP Won't shift 2-3 at WOT
Old Oct 22, 2005 | 08:21 AM
dtuckz28's Avatar
Default HELP Won't shift 2-3 at WOT
I have a problem with my car not shifting from 2-3 at WOT in drive it hits the rev limiter almost everytime. The car shifts fine in overdrive at WOT. It also shifts fine while driving normal. Im planning on adding a 3500TCI and a 150 Dry kit soon so i need the car to shift correctly. Is this a programming problem or mechanical?
Old Oct 22, 2005 | 09:09 AM
jxaxsxoxn's Avatar
Year, miles, current mods to the engine and trans??
Sounds like the 3-4 clutch is going.
Old Oct 22, 2005 | 12:05 PM
dtuckz28's Avatar
1998 90000 SLP lid, bellow, SLP mass, hypertech programmer, 3.73 gears
Old Oct 22, 2005 | 12:20 PM
meSSman02's Avatar
I would definatley think about a rebuild before a stall and spray especially with that many miles on the tranny.
Old Oct 22, 2005 | 12:24 PM
spy2520's Avatar
i have the same problem and i have around 77000 miles. mine is also a 98 but it hits the rev limiter every time at WOT.
Old Oct 22, 2005 | 02:03 PM
jxaxsxoxn's Avatar
Ok I'd like to get to this with as few posts back and fourth as possible.
So..............................What are the transmission settings for the trans?
Shift time, duration, i don't know everything.
Old Oct 22, 2005 | 03:28 PM
GDM Z28's Avatar
Same thing was happening to my car....turns out my fans werent working and the car was running alittle hot....once i fixed the fans and the temp dropped the car started to shift. Also have you changed your shift points because of the new gears? try lowering your shift poitns some.
Old Oct 22, 2005 | 06:46 PM
dtuckz28's Avatar
I have not tried changing shift points but its worth a try. The only thing is that it was not shifting when it was totally stock without the gears. Can somewhere like a transmission shop program the car to shift at whatever RPM you want?
Old Oct 22, 2005 | 07:48 PM
GT Griller's Avatar
Well u can adjust it with ur HPP3.
Old Oct 27, 2005 | 11:26 PM
electricz28's Avatar
I have seen more trannys killed by the HPP3.
Old Oct 28, 2005 | 01:59 AM
SmokingWS6's Avatar
Before you rebuild your transmission there's a few things you need to know. one, hyperstuff is junk, reflash it to stock. 98's are extremly picky with high speed stalls. Shift points need to be set as low as 5500rpm just to make them shift by 6000+ rpm. I've tuned countless 98's that have suffered from this problem. Find somebody in your area with hp tuners that can work on your 2-3 shift settings before you determine the trans is shot.
Old Oct 28, 2005 | 06:17 AM
Automatics's Avatar
Restricted User
The vast majority of times it is (1) not enough pressure, (2) not enough volume of oil to the 3-4 clutches, (3) not enough 3-4 clutches, 6 stock, 8 recommended, (4) too much 3-4 clutch clearance, etc. You can see that there is a lot to this? If I can be of help, let me know?
Old Oct 28, 2005 | 07:52 AM
Ragtop 99's Avatar
This is not uncommon after a gear swap. Many people experience this quirk after a gear swap. If it shifts fine with the selector in OD, but not in D, then race with the car in OD. I've known plenty of people who experienced this and their tranny's did not break.
Old Oct 28, 2005 | 11:19 AM
GT Griller's Avatar
Mine shifts short on the 1-2 shift after the gears. It only goes to 5700 or instead of the usuall 6100.
Old Oct 28, 2005 | 11:50 AM
spy2520's Avatar
yeah thats just about all the things i've heard...dont forget (5) shift points and (6) VSS and (8) which is a new one i've been hearing, the pressure switch module?? i'm still on the fence as to what to do to the trans, since i dont know whats really wrong with it.
Old Oct 28, 2005 | 05:04 PM
Craigz28ss's Avatar
I had the same problem for a while. I thought it had something to do with the tunnig so I spent alot of time tring to fix it with HP Tuners. Somtimes while logging a run at the track I would notice the speed on the graph drop to zero for just a second. I thought this might be the VSS malfunctioning so I decided to replace it. After that my problem was gone and I could accuratly adjust my shift points again.
Old Oct 28, 2005 | 05:10 PM
camaronut502's Avatar
where is the VSS located? im having the same problem and ive been adjusting my shift points/mph and its not helping. Also will making a run in OD act any different then in D?
--Matt
Old Oct 29, 2005 | 04:36 AM
spy2520's Avatar
did anybody catch that i said (5) (6) (8) in my post above?
i must have forgot what (7) was...
