TH400 question, shifting from reverse to first kicks HARD!
I have a reverse manual valve body th400, a chromemolly driveshaft, and a 12 bolt rear end. When I shift it from reverse into first, it makes a very loud bang and kicks very hard. Is this normal or is something wrong in my setup? I am not sure if the banging sound is coming from the trans or from the rear end. It basically always did this from the first day that I had the setup installed. Any way I can diagnose things? thanks
Thanks for your replys. It is very possible that he didn't think that I would daily drive it, as it is a reverse manual.
How can I check if the U-joints are bad. They have about 1500 miles on them as its a new driveshaft, but prety much for the entire time the torque arm has been set and still is at a wrong pinion angle. thanks
