Does a new torque converter need an easy break-in period?
The way to do it is drive the car or truck at light throttle for about 50 miles then start to increase throttle amount a little at a time, then get up to highway speeds tap the brake (this will allow the converter to lock and unlock)
do this around 50 times to help seat in the new clutch and matting surface
it will take about 150 miles to seat the bearings,roller clutch and the clutch.
DO NOT brake stall or go full throttle with a converter that has a clutch untill this is done!!!
doing this will cause the roller clutch,bearings or the clutch's life to be reduced by a lot!!
Most converter failures happen from brake stalling the converter just after it was installed!
Thank's for asking this!
Mike
Dunno if vig's are made any different or not or maybe i got a good one
50 miles doesnt seem like to far anyway.. just getv to driving and then nail it after 50miles
Mike
Thanks, Mike. I have a heads/cam/longtubes, etc., C5. I have ordered a Yank SS3200 for it and plan on keeping my 3.15 gears. Also, at the same time, I'm going to be installing a Shaner ported throttle body. I know the SS3200 is supposed to be pretty tight, which is why I ordered that particular model as I want maximum drivability, but figured the Shaner would also increase the perception of tightness by increased throttle response.
When I get both installed, I will take the car back for a week, or so, in order to follow your instructions on converter break-in, after which I will let my tuner have his way with it to clean everything up. I will be gettting another dyno run with it, also, and do not want to do that with the fresh converter.
Thanks for the advice, I really appreciate it!
Ed
Mike
let's go over your instructions. as i do not want to void my warranty because i didn't follow these instructions that were not provided with my converter.
what do you consider light throttle for the first 50 miles?
what is highway speeds? 60? 70? 80?
should i do the unlock/lock 50 times in a row? or say once every 5 miles? 50 times for 100 miles after the first 50 miles.
To start with you need to seat the roller clutch in as it takes the over run action ( locking & unlocked and spinning at engine speeds) to polish in the surface of the rollers inner race and outer race or cam in the stator.
also the roller bearings in the converter need to smooth out and polish in,
the clutch surface is still rough as it is new and will need to seat in also
to do this drive normal with no max throttle for about 150 miles (any speed is ok for this)
cycle the clutch this action will work harden the lining material and allow full contact area the same as a brake in on a new set of brake pads and rotors.
when you go WOT it puts a extreme load on the internals and if they are not in shape you can get the roller clutch or sprag to fail and the lock up surface to glaze.
Failure to follow brake-in will shorten the life and effect the performance of the unit.
I will have a complete Brake - in sheet posted on our site soon
www.converter.cc
Thank's for the ?
Mike
Matt
www.converter.cc
Thank's for the ?
Mike
when will you include it on your boxes when you ship a converter?
now which is it?
