Where to place tranny temp sensor in TH400?
I was reading that on the 4L60e's there is a plug on the passenger side of the trans that you can use to put a temp sensor, but what about a th400? I was under the car with a light and couldn't see any port or plug were I can put a sensor in. Anyone know? I am about to change my trans cooling setup, and wan't to be able to document the difference in cooling.
Right now I have a Permacool 30,000 cooler in front of the radiator, and a 18,000 or so B&M cooler mounted dope style. I want to document what the temperature stays at with this setup that I have had for the past 2 months, then see how it is compred to when I take out both coolers, and install my new B&M cooler with fan.
Thanks
Thanks
