Using the Hypertech to adjust shift points after custom tune
Old Feb 19, 2002 | 11:18 PM
key master's Avatar
Default Using the Hypertech to adjust shift points after custom tune
Can I do it? I used to have ed wright tuning and I used my hypertech to program over it with no problems. Ed wright almost had a cow when I told him that I did it though. <img src="gr_stretch.gif" border="0">
I want to have my current ecm (which is currently back to STOCK) tuned with ls1-edit and I wanted to adjust ONLY the shift points with the hypertech, leaving everything else alone... possible?
-Jim
[ February 19, 2002: Message edited by: key master ]</p>
Old Feb 20, 2002 | 05:49 AM
ChrisB's Avatar
Default Re: Using the Hypertech to adjust shift points after custom tune
Moving this to the computer section (from drivetrain section)
This should be possible as I understand the LS1 pcm can program a segment of the chip at a time (instead of re-programming an entire image).
Chris
[ February 20, 2002: Message edited by: ChrisB ]</p>
