Converter Install Questions - PLEASE HELP
My tranny did not budge after removing the driveshaft, transmission crossmember, and torque arm nuts. Two of the three torque arm bolts are still in without the nuts because there is not enough room to pull them out. I did move the clamshell bracket aside as noted in http://www.modernmusclecars.net/articles/TCinstall Shouldn't the tranny drop at this point? In the article it says that you need to drop it to remove the transmission cooler lines. I have not removed the lines because they are too far up on the tranny. Do I need to remove the tranny cooler lines before lowering the tranny or is there enough flexibility to leave these in?
Also we decided that the stupid transmission dipstick tube is unreachable. We tried a wrench, but it will not reach the 15mm bolt on the block. How do you get to that bolt? Can I leave the dipstick tube attached if I can't reach the bolt?
Also the article says the remove the Y pipe on a stock exhaust system. So far it does not appear to be in the way at all. Is it really necessary to remove the y pipe?
Any help is greatly appreciated. THANKS
There is some flex to the cooler lines, but not enough to drop the tranny, we got mine off while it was still up in the air. I'm assuming you dont have a tranny jack, so you definitely need to get them off before you try and lower the tranny.
I have an aftermarkey Y and didnt have to remove, cant help you with that one. The dipstick tube we left attached and just removed it from the tranny itself. Hope this helps
You also need to remove the torque converter bolts and let it stay with the trans when you remove it.
