M6 to A4 questions
Old Feb 22, 2002 | 06:15 PM
CoopDog's Avatar
Default M6 to A4 questions
I just ordered a 4L70, I have a few questions. Do the A4 cars have a block off plate where the 6-speed shifter hole is? I obviously need something to cover the hole. I have been thinking about the standard Hurst QuarterStick for a shifter, I got a reverse manual, so I need something that will work with that.
Old Feb 23, 2002 | 12:21 AM
BIGBOS's Avatar
Default Re: M6 to A4 questions
Well I am changing to a th400 from a 6-speed....
I am using the B&M hammer shifter, and the stock console with the shifter boot will still be on it, so it will look like a 6-speed with a different ****....
You should be able to use the same console
Old Feb 23, 2002 | 08:34 AM
CoopDog's Avatar
Do you have something to blockoff the hole though?
Old Feb 23, 2002 | 10:04 AM
BIGBOS's Avatar
There was some pretty good pics of the install that macgyver did on here with his t-56 to th400 swap...the shifters usually take up all the space...and then he fabricated something for the shifter to sit on
Old Feb 24, 2002 | 11:36 AM
CHRISPY's Avatar
I used the existing six speed console in my 4L70 swap. Looks stock.
Thanks,
Chris
Old Feb 24, 2002 | 11:54 AM
LT4vert's Avatar
Heres what your looking for <img src="gr_images/icons/cool.gif" border="0">
https://ls1tech.com/ubb/cgi-bin/ulti...c&f=2&t=000515
Derek
