Any difference in LT1 and LS1 4L60E?
Old Feb 24, 2002 | 08:38 PM
Whistler's Avatar
Sawzall and Welder Mod
Default Any difference in LT1 and LS1 4L60E?
Anyone know if a auto trans from a 94-97 LT1 can be used behind an LS1 if the appropriate torque converter is used?
Old Feb 24, 2002 | 09:41 PM
FastAl's Avatar
Default Re: Any difference in LT1 and LS1 4L60E?
If I'm not mistaken an LT1 has the standard SBC bolt pattern on the tranny/engine whereas the LS1 is a different bolt pattern.
Old Feb 24, 2002 | 09:48 PM
Kurt D's Avatar
I think the LS1 has the standard SBC bolt pattern for the trans, but I think the flywheel is different so you'll need the right converter. People use turbo 350 and 400's on their LS1's so in theory I'd say yes it will bolt up and work unless theres an electronic difference (connections, programing, etc.)
