There here!! Yanks new converters
The Pro Eliminator 4200
and the new SS3400
for all G.M. transmission types
they have killer intro pricing too!
Thank's for your time
www.converter.cc
but:
the SS3400 is a new stall speed to the SS line (3200,3600,3800&4000)
Pro Eliminator 4200 is a replacement for the PT4200 with improved performance in driveabilty and top end pull!
and look at the new low pricing
What kind of improvements do you think I would see going from a PT4000 to the PE4200?
Thanks
John
all that means is pull harder to shift point and put more HP to the ground after the shift.
An ET reduction of .12 to .15 and the MPH plus of .8 to 1.2 mph over the PT4000 in the same vehicle
i have the ss4000
i wanted to get a six-bolt like the ss4000E for nitrous later
but the PE4200 has this?
i didnt want a PT4200 because i heard its too loose for a daily driver
(only car!)
but the PE4200 has 2.6STR like the ss4000
and i think the ss4000 is okay for street
will the PE4200 feel much looser with 200+ stall and same STR?
will there be a noticeable difference in performance from ss4000 to PE4200?
the PE 4200 and SS4000 will feel very much alike with a 3.23 and 3.42 gear
when used with a 3.73 or 4.10 the SS4000 will have start to slip less,at the middle RPM range and have a better throttle tip in feel(when unlocked)
and the PE will have a longer torque range this will allow for the great shift extension like the PT series.
The SS4000 converters will not pull from a WOT downshift as well as the PE or PT converter with A NA engine
But if NOS is in the plans the SS4000 will be the choice for over a 125 shot.
the 6 lug cover and clutch allow for all holes to be used with aftermarket flexplates and this clutch will handle lock up very well at the track and still perform on the street some thing that is hard to balance in a converter with a high stall.
we would like to hear about your ride
the ss4000 will feel tighter sooner,
and the PE4200 will have better SE
and stronger WOT downshift
i WOT downshift all over town,
so that is important to me.
after a WOT shift,
rpm drop on the stock tach from 6000 down to 4700 with the ss4000
can you tell me where my rpm would drop to after a WOT shift with a PE4200?
and i read "An ET reduction of .12 to .15 and the MPH plus of .8 to 1.2 mph over the PT4000 in the same vehicle"
the PT4000 performs better than the SS4000?
i can expect more improvment then that?
Yes the PT is faster than an SS converter of the same stall in an NA car
and the PE4200 is up on the PT4000
but every application is different, so I am guessing about .20 or more in your car.
I just can't give you exact # as I have seen the same converter Knock off from .500 to 1.10 in the same setups, (drivers,cam and traction, ect) all have an impact.
The PE4200 converter has many hours of design and testing involved to give the performance converter buyer a ''best in class'' product
Give us a call, we would like to get more info on your setup
775 826 9955
I'm not going into details of my setup cause thats my secret but yank knows their stuff.
A .12 -.15 improvement over a PT4000 is very impressive! I cannot wait to see some track results.
John
and the new SS3400
www.converter.cc
Super Stock 3400? I do not see it on the web site? I see the 32, 36, & 4000; but I don't see the 3400. What is the STR on the SS34000? I am looking for something in the lower 1.7-2.2 range.
