tranny question
Old Nov 17, 2005 | 12:33 AM
Shooter9's Avatar
Default tranny question
OK going to try and explain, OK say I'm in first gear and I'm running around 4,500 rpm I let off of the gas how come I dont have back pressure to let the pipes talk so to speak, when I do this the rpm's fall down to ideal. Is their anything I can do to fix this?
Old Nov 17, 2005 | 02:11 AM
Automatics's Avatar
Restricted User
The sprag assembly (clutches, sprag, overrun hub) is the problem here, that is why no engine braking. The transmission must come out for this to be fixed.
