Tranny slip
Old Nov 18, 2005 | 07:55 AM
JeanSS's Avatar
Default Tranny slip
I had my auto tranny serviced in my 01 SS camaro at the local chevy dealer and ever since then at slow speed less than 10 mph while still in 1st gear it seems to slip to neutral when I let off the gas and it will grab suddenly when I give it gas and RPMs catch up to that speed, anyone know whats going on here?
Old Nov 18, 2005 | 08:41 AM
Reject's Avatar
first, what was done to the car? knowing where they were at under the car probably will help others have an idea as to what it is.
Old Nov 18, 2005 | 03:20 PM
JeanSS's Avatar
Default Tranny slip at slow speed
The dealer did a complete flush and refill and new filter. The car has 43000 miles
Old Nov 18, 2005 | 08:23 PM
TeamTripp's Avatar
When it does this, does the engine seem to rev freely, or does it just feel like its in a higher gear?
Is it possible they have have messed with the shift linkage at all?
Old Nov 18, 2005 | 08:27 PM
cam75w/ls1's Avatar
Did you check the fluid level? Is this car driven hard?
Old Nov 18, 2005 | 09:30 PM
Automatics's Avatar
Restricted User
The overrun assembly not holding (overrun clutches, overrun hub, overrun sprag) can cause this to happen.
Old Nov 19, 2005 | 08:44 AM
JeanSS's Avatar
the engine seems to rev freely. thamks for the response.
the car is not driven hard my wife drives it lik it has a 4 cylinder.
