4L60E experts, need some help
Old Feb 26, 2002 | 10:28 AM
HardCoreTA's Avatar
Default 4L60E experts, need some help
I'm planning to do a near complete tranny rebuild, with new servos, input sprag, kevlar powerband, clutches, pressure boost valve, reaction shell, cast aluminum pan, plus HD springs, pumps, etc. I'm also planning to install a Vig 2800. I've heard a lot about problems with Torque Management with certain converters and shift kits (which is why I'm not using a TransGo). My question is, do you think any of the replacement parts I mentioned above will interfere with TM? The company that manufactures the parts doesn't think so, but they honestly don't know. Thanks.
Old Feb 26, 2002 | 01:59 PM
WILWAXU's Avatar
Default Re: 4L60E experts, need some help
Torque Management is a computer problem not a converter problem. If you have a 2001 & up you will likely run into TM issues. Your best bet is to go with the mods you want and do custom tuning if TM becomes an issue.
Old Feb 26, 2002 | 06:26 PM
HardCoreTA's Avatar
Yeah, I know TM is all programming, but I wasn't sure if these parts (servos, pumps) were monitored by the PCM and TM. I don't want to spend a sh*tload on parts and have them be useless. <img src="gr_stretch.gif" border="0">
