C5 automatic ?s
Old Nov 25, 2005 | 03:11 PM
whitt1's Avatar
Default C5 automatic ?s
Can a C5 automatic transaxle and convertor be bolted directly to a LS1 motor in a mid-engine configuration?Has anyone attempted this conversion?
Old Nov 25, 2005 | 03:24 PM
Yank's Avatar
Yes you can do this!
use the 4.3 s10 or non ls1 4l60-e bellhousing and c-5 converter
but it is very long right at 55" axle center line to front of waterpump
we have sold kits for buggys
Old Nov 25, 2005 | 03:40 PM
whitt1's Avatar
Is it possible to fabricate a shorter bellhousing or to locate the converter at the rear of the transaxle?
Old Nov 25, 2005 | 04:04 PM
Yank's Avatar
you can offset & turn the trans around 180 then run a a drive shaft setup and also run the engine backwards that will shorten it up to about 30"
But how much do you want to spend
A 4t80-e with an Ls1 side mounted would be better setup or even a 5.3 out of the new Monte Carlo SS
Old Nov 25, 2005 | 04:12 PM
whitt1's Avatar
I've got a Lotus Europa in the garage that I was thinking of dropping a LS2 motor into kind of thinking about $5000 in tranny and converter.Any more that that I can go with a Porsche tranny for less.
Old Nov 25, 2005 | 04:16 PM
Yank's Avatar
I think the 4t80-e or the new 4t65e HD with the LS2 would fit as you have about 20" from the foward head to axle centerline
Old Nov 25, 2005 | 04:34 PM
whitt1's Avatar
My engine and transaxle are mounted north/south,with the motor in front of the transaxle,about 26" from crank pulley to halfshaft centerlne.
