LCA install question
Old Feb 27, 2002 | 08:45 PM
Palm Beach Z's Avatar
Default LCA install question
I finally decided to get lower control arms for my car. (Running out of stuff to do to it.)
I got the BMR tubular poly/rubber.
Does the rubber bushings go towards the front?
Thanks. <img src="images/icons/rolleyes.gif" border="0">
Old Feb 27, 2002 | 09:54 PM
mcflyz28's Avatar
Default Re: LCA install question
body side, yea the front of the car.
Old Feb 28, 2002 | 12:21 AM
flyin red TA's Avatar
No instructions?
Grease fittings point down.
Good luck with the install, my tubular poly/polys were a bitch.
Old Feb 28, 2002 | 11:53 AM
bigSS's Avatar
I also have the BMR poly/rubbers... I put the rubber on the front (body side). I thought they were quite easy to install.
I also did not recieve instructions. <img src="images/icons/rolleyes.gif" border="0">
[ February 28, 2002: Message edited by: bigSS ]</p>
Old Feb 28, 2002 | 05:16 PM
Thanks everybody for the help. They're going on Friday night. <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Feb 28, 2002 | 06:23 PM
Actually mine going back in weren't bad, the main problem was getting the old ones off. I have a 98 with 40k miles so some of those bolts were really stuck in there.
Old Mar 1, 2002 | 12:52 AM
TATERBUG01's Avatar
You can put them in the freezer, and that will make the bushings contract. Will be easier to slide them in then. That will work on ANY suspension bushing, ESPECIALLY poly ones <img src="gr_tounge.gif" border="0">
