Will a Trans Go shift kit aleviate a p1870 code?
Old Nov 28, 2005 | 11:25 PM
MetallicBluews6's Avatar
Default Will a Trans Go shift kit aleviate a p1870 code?
Does anyone know if a Trans Go shift Kit would help a p1870 code?
My mods are in my sig a TCI ssf 3500 stall, transcooler and tune in regards to transmission work. Do you guys think that a Shift Kit would help?
Thank You
Sincerely
Robert
Old Nov 28, 2005 | 11:26 PM
Car only has 28,000 miles.
Old Nov 29, 2005 | 09:01 AM
Translation, p1870. Code means converter is slipping. Converter is only 3 and a half months old.
Old Nov 29, 2005 | 11:05 AM
lt1dave's Avatar
Your converter IS slipping. Delete the code
Old Nov 29, 2005 | 01:45 PM
TeamTripp's Avatar
That code sets when the converter stops locking (it only sets when the converter is commanded to lock up) meaning a loose converter won't set it. An inoperative converter clutch will.
As far as the TransGo kit fixing it, that depends on why its setting. If its setting because the valvebody is worn out, then yes, it will. If its setting because the solenoid is bad or the converter is bad, then that won't fix it.
Old Nov 29, 2005 | 02:09 PM
lt1dave's Avatar
Your right, I saw the 02 car, and was thinking of 1875.
Old Nov 29, 2005 | 08:12 PM
Thanks. I hope that it is the valve body.
