just bought my transgo s/k
Old Dec 3, 2005 | 05:46 PM
MiaSSmaro98's Avatar
Default just bought my transgo s/k
hey guys just bought the transgo shift kit today.i was wondering after looking at the install video is it a neck snappng kit or just a kit to firm up stuff?i want strong kneck snapping going into second.also i bought it because my tranny gave up at 104k miles so its time to rebuild.i have a 98 ss a4.
Old Dec 3, 2005 | 06:27 PM
LT1PWRD's Avatar
Which kit did u get? What trans-go model/part# kit. They all usually have firmness options,in the form of separator plate hole sizes and accumulator shims.
Old Dec 3, 2005 | 08:10 PM
jxaxsxoxn's Avatar
All you need to do to get neck snapping 1-2 shifts is put all the shim washers in the 2nd accumulator. Drill the second feed to .093, adjust the band right, delete torque management.
You'll have annoying, neck snapping tire chirping shifts.
If you want to really **** yourself off don't put anything in the 2nd accumulator except for the piston and a stack of 3/8" nuts on the pin to block the movement of the piston, you'll hate it 100%.
Old Dec 3, 2005 | 08:55 PM
Automatics's Avatar
Restricted User
If you are looking for long life on this unit "do not" add any spacers to the 2nd gear accumulator. This unit should shift smooth at light throttle openings, and the shifts getting firmer with more throttle. It should brake the tires loose from the HP you are putting out and not so much from making the transmission shift hard. Hard shifts at light to medium throttle openings, are not necessary & hard on the driveline all around, and can be dangerous, besides your women would hate it.
Old Dec 4, 2005 | 08:46 PM
that i know of transgo only has one kit.the kit in some locations states drill this size for street and drill this size for full race /high converter.what should i do?
Old Dec 4, 2005 | 10:23 PM
GT Griller's Avatar
Sorry for hijacking the thread, but Hey does the Transgo allow for full manual? I want it to shift instantley when i move the shifter.
Old Dec 5, 2005 | 09:38 PM
LT1PWRD's Avatar
Miassmaro98,There are a few kits by trans-go for the 700 through 4L60E. the hole size will depend on personal preference and veh. application.
GT Griller,That is an option in HD-2 Trans-Go kits. for 700-R4's and 4L60E's just diff. part # kits for the diff tranny's (electronic or not)
Old Dec 9, 2005 | 09:41 PM
i have the psk4l60e kit which is the performance shift kit.im putting one spacer in the 2nd acum and drilling all the wholes in the seperator to .093
Old Dec 9, 2005 | 10:14 PM
LT1PWRD's Avatar
I think the 1-2 firmness opt is "prefer .063,firmer.070" and the 3-4 may be diff than .093, i may be wrong,i did one last week and can't remember for sure. I do know in the shift correction (not perf) kits,most holes are 0.093. lemme know
Old Dec 10, 2005 | 12:27 AM
rjkZ28's Avatar
i had the trans go shift kit installed about 1 1/2 months ago and no problem, runs like what Pro Built Automatics said
Old Dec 10, 2005 | 01:06 AM
sidewayz28's Avatar
correct me if im wrong...shift kit just improves shifting basically right? just shifts faster? how much do these usually cost? im assuming not too much..and how much would you estimate on an install?
Old Dec 10, 2005 | 08:51 AM
jxaxsxoxn's Avatar
Those 1-2 shift hole sizes are what they say in the older kits that came with the video. It's the more user friendly kit.
The newer "for professional installation only" type kits such as the 4L60E-HD2-B use totally different hole sizes. I don't know why.
I have the HD2-B kit and the 2nd feed they say to drill to .082, mine was already that size from the factory.
The HD2-B kit basically has you drill all of the selected holes to .093.
Old Dec 12, 2005 | 01:49 AM
Automatics's Avatar
Restricted User
The "late" Trans-Go HD2 kits were detuned because of Torque Management. If you get rid of Torque Management, and use a 9.5" torque converter, then you can do much more with this kit to get it to hold up to more horsepower. You can change the 1-2 feed to .096, & leave out the spacers if you want a smooth 1-2 part throttle shift, and firm WOT shift. For the 2-3 .155-.187 works very well for me, and the 3-4 can be .125-.155. .155 will work well for WOT 3-4 shifts. Stay with the Corvette style servo, the billet is overkill & can create problems. I hope this helps.
