Properly sizing a converter...
Old Mar 7, 2002 | 08:00 AM
BIG NUGGETS's Avatar
Default Properly sizing a converter...
What is a good basis for sizing a converter? I'm running H/C car with stage II heads and 224/224 581/581 112 cam. Currently the car has about a 4800-5000 stall in it. Is that to much? Just want to get the most out of my N/A set-up.
Thank you.
Old Mar 7, 2002 | 08:21 AM
Patrick G's Avatar
LS1 Tech Administrator
Default Re: Properly sizing a converter...
The stall could be right or could be wrong...it's not just about stall speed but other things like shift extension, efficiency and converter diameter. What converter are you running right now?
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Mar 7, 2002 | 08:23 AM
Raughammer's Avatar
D(irecto)r Pepper
How high of RPM's are you turning the motor? What rear gears are you using?
What tires do you use?
What kind of racing are you most interested in? street? drag?
Old Mar 7, 2002 | 08:50 AM
RyanJ's Avatar
SSU Moderator
Heres my selection chart...its REAL easy.
STREET (any motor) <-- for drag radials, street tires, etc.
Super Yank 3500
Street/Strip (SI, C, HC, S, dont matter) <--basically you middle of the road converter.
Vigilante 3200 (any year, NO SES LIGHTS!) OR Super Thruster 3500 (NOT for '01 and up)
TRACK (SI, HC, dont matter) <-- Hard core.
Thruster Pro 4400
NITROUS (out of the hole, any motor)
Vigilate 2800
Thats all i would ever use. the "middle" converters (V3200/ST3500) will work well with any gear and with any motor including strokers.
You shouldnt need any other converter
well, unless you dont mind loose converters and dont want to change your gears....the Viglante 3600 or 4000. They will give great 60's with 3.23's.
Old Mar 7, 2002 | 08:54 AM
TimZ28's Avatar
That sure sounds like an XE-R cam so that would lead me to believe you are serious about the performance of the car. I'd be looking for a converter somewhere in the mid 4k range and shifts around 6700-6900. Anything less and you really won't be taking advantage of that camshaft.
Tim
Old Mar 8, 2002 | 11:43 AM
Good guess, Shifting at about 6850. Cam is a XE-R cam. Not bad. The stall is a P.I. that has been modified to be more efficient on the top end. Browsing through Yank's website i'm thinking maybe I need to decrease in size to a TP4400. I just want to use the cam as efficiently as possible. I don't want to be too high.
Additional info-26x16x11.5 ET streets/3.23 gear
[ March 08, 2002: Message edited by: BIG NUGGETS ]</p>
Old Mar 8, 2002 | 01:39 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Where is your peak TQ and HP being made, and how far does it carry each of them?
__________________
