convert 4wd 4l80e to 2wd
Old Jan 6, 2006 | 01:34 PM
cablebandit's Avatar
Default convert 4wd 4l80e to 2wd
what is involved in converting a 4wd 4l80 to a 2wd besides swapping the tailhousing?
Old Jan 8, 2006 | 11:52 AM
Greaseymec's Avatar
The output shaft also has to be replaced. Be carefull! there are differences in design between year models. Make sure you get the same design shaft.
Mec
Old Jan 8, 2006 | 12:24 PM
john kilgore's Avatar
Default lube
l also believe that a lube hole must be drilled. l can find out if you are interested.
Old Jan 9, 2006 | 08:17 AM
thanks for the info...no info needed as it seems to not be a simple tailhousing swap
