problems with breaks and vac modulated
Old Jan 8, 2006 | 11:04 PM
Tiger2o69's Avatar
Default problems with breaks and vac modulated
Just installed a vac modulated trans and the breaks work fine until i do a burn out and then pull up to the line. they get hard to push down and then i have almost no brakes after my run. Whats going on?
Old Jan 9, 2006 | 08:11 AM
cablebandit's Avatar
sounds like your brake booster checkvalve is faulty. It is on the end of the hose that plugs into the brake booster....1 minute fix
