Need Flywheel bolt Answer!!!! QUICK!!
Old Jan 13, 2006 | 11:02 PM
kTkz2800's Avatar
Exclamation Need Flywheel bolt Answer!!!! QUICK!!
I was trying to take my 4l60e out and i ran into a problem it wont catch gear to let me take the flywheel bolt out... so im stuck what do i do????
Old Jan 13, 2006 | 11:07 PM
BrokenTA's Avatar
what do you mean flywheel bolt? Are you talking about the torque converter bolts or the bolts that bolt flexplate to the crank?
Old Jan 13, 2006 | 11:28 PM
SUX2BU's Avatar
yeah what he said.
Old Jan 14, 2006 | 12:43 AM
kTkz2800's Avatar
the flywheel to the TC
Old Jan 14, 2006 | 01:34 AM
The Sad's Avatar
You need to hold the flywheel. There should be an access plate in the tranny that will let you put a larger screwdriver or something in the flywheel/flexplate teeth to hold it while you break the bolt loose.
Old Jan 14, 2006 | 02:37 AM
CAT3's Avatar
Restricted User
You dont need to unbolt the flywheel to remove the trans. You do need to remove the starter, and remove the 3 TC bolts. With the starter removed, you rotate the flywheel until you can use a couple long extensions on a ratchet, then while you hold the flywheel as mentioned above, or by the crank pulley bolt, you remove the TC Bolts, rotate, remove and repeat one more time. This unbolts the TC from the flywheel and thus allows you to remove the trans.
Old Jan 14, 2006 | 07:24 AM
kTkz2800's Avatar
ok the screwdriver thing was my first tought but i wasnt too sure cuz i was afraid... hilly billy mechanics.... but i guess we will see im not taking the flywheel off...just the tc bolts!
