where to mount trans cooler? pics?
where is everyone mounting theirs? ( I have my supercharger intercoolers up under the car and can't mount it there.
Anyone mounting it in front of the radiator?
how do I go about disconnecting the stock lines, can I just run 3/8 rubber line to the stock metal lines and connect it with hose clamps?
I guess some call this the Dope style.
I have another one in front of the condenser.
Do a search on this, there were pics a couple of days ago on some people's installs.
http://www.fear.net/~dope/camaro/tranny_cooler/
Hope this helps you. <img src="gr_stretch.gif" border="0">
I ran the tranny lines through the weep holes at the bottom of the radiator support - just had to widen them a little and the hoses fit right through.
I took some 3/8" rubber hose and cut it in half, and used each half to provide a cushion between the tranny cooler and the condenser, so there would be no metal-to-metal contact to wear a hole in the condenser. Just held everything in place with some long zip ties that go through the condenser. It's very stable.
Don't have any pics though.
