Charging probs with ST3500...
Old Mar 11, 2002 | 11:55 AM
INSSANE's Avatar
Default Charging probs with ST3500...
Every so often it seems as if the car's power surges. By power I mean the battery level dips and headlights dim. When I start it up cold, I put it into drive right away and gave it gas and it died out! Is there a solution to this?
Nick
Oh yes, also had BM cooler, Transgo, and poly trans mount installed at same time (prob unrelated)
Old Mar 11, 2002 | 11:58 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Default Re: Charging probs with ST3500...
Try turning off all the Neon lights <img src="gr_tounge.gif" border="0"> <img src="graemlins/gr_jest.gif" border="0" alt="[jester]" />
Is the idle surging too, or just the volt meter? My idle used to surge a little after my ‘verter went in (volt meter and oil pressure would surge too). Now that it’s been raised to 850 it doesn’t do that anymore...
Old Mar 11, 2002 | 01:56 PM
MitchR's Avatar
I had to up my idle just slightly. You can do this one of two ways without programming. Either drill the hole in your throttle blade out a bit to allow more air in OR the way I did it was to find a allen wrench of the correct size and turn the idle set screw on the throttle body so that it opened up the TB blade just a bit more. Mine idles around 600-650 now and I almost never have the problem you are talking about.
- Mitch
Old Mar 12, 2002 | 12:00 AM
INSSANE's Avatar
A tiny bit of idle surge.
and Haha! <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Nick
Old Mar 12, 2002 | 12:03 AM
Ragtop 99's Avatar
If it was just installed, the PCM needs to learn that it has a lighter converter. Give it a week or do the PCM relearn.
Old Mar 12, 2002 | 12:04 AM
INSSANE's Avatar
Where can I find the PCM relearn?
Nick
Old Mar 12, 2002 | 12:12 AM
SIR's Avatar
SIR
Never had that in my ST3500. Give the PCM about 100 miles + to relearn the new converter. Mine surged a lil when it was first put in, but after a few days it was good to go and have had zero problems since.
