A to Z TH400 Install ?
Old Mar 14, 2002 | 01:54 PM
[JFS]'s Avatar
Default A to Z TH400 Install ?
Does anyone have an A to Z writeup of a TH400 install for a 4th gen?
I have a quasi-dead 4L60 in my '93 LT1 TransAm. With a supercharger going on and an eminent rebuild, I'm looking to make the big jump and save a few bucks in the long run. In a few months I plan to get a GV overdrive unit <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Any instructions as to what I would need?
Old Mar 14, 2002 | 02:26 PM
Reckless's Avatar
Super Moderator
Default Re: A to Z TH400 Install ?
The "easiest" route can be found here: www.converter.cc
Yank makes direct bolt-in replacements. I have been happy with mine. Depending on how savvy you are with fabrication, you could do it yourself for less money. If your time is important, talk to Mike at Yank.
Since your car is a 1993, it should have the 4l60 (not computer controlled 4l60e). This will be easier because you won't have to deal with computer issues.
Old Mar 15, 2002 | 10:13 PM
GeorgeC's Avatar
There really aren't any "fabrication" issues with the exception of the crossmember and the tranny dipstick/tube.
I just welded a piece of steel plate onto the my crossmember to make it work. The easiest dipstick solution is the flexible Lokar dipstick. I think Madman Racing also sells a TH400 dipstick assembly as well.
Old Mar 15, 2002 | 10:38 PM
Reckless's Avatar
Super Moderator
I did the same as you for the cross member George. The Yank kit comes with a Lokar dipstick.
Todd
Old Mar 16, 2002 | 10:12 AM
MacGyver's Avatar
Here's just what you're looking for. It's slightly different for you since you're going from a 4L and this guy went from a T-56. But it should help you out alot. I got alot of my info from this site
http://para.noid.org/~lj/TH400/TH400.htm
