M6 to A4
Old Jan 25, 2006 | 12:02 AM
1BadSS 00's Avatar
Default M6 to A4
I am intrested in doing this. can some one list what is needed for the swap, also how much this would cost, and how hard to do by my self/with friends..
Old Jan 25, 2006 | 10:10 PM
TA TECH's Avatar
As in to a 4l60e or th400.From a M6 to A4 a th400 will be alot easyer that the 4l60e because ya need the wiring harness, wouldn't hurt to have the a4 pcm swap crossmembers on both!The wiring to do in the car is a pain lights so if ya went to the th400 or similar all ya would have to do really of hardness is wire up the rev lights and stuff on inside!Just stuff I run into!Everyones ideas may vary!Ya can run a search on it should be alot of info.That is if the seach is working!
Old Jan 26, 2006 | 12:12 PM
peteTA's Avatar
i have a 2001 ws6 with 23000 miles on it. i bought it wil 19000 miles on it. I use it as a daily driver and have never taken it to the track. I want to get a M6 conversion. If you want to work something out get back to me, maybe we can swap eachothers. Later Redbull660r@aol.com
