Effects of air temp on converter performance?
Old Mar 18, 2002 | 01:49 PM
JNorris's Avatar
Moderator
Default Effects of air temp on converter performance?
I know that an engine will produce more HP the cooler the air temp is to a certain point and the same engine will produce less HP the hotter the air temp is.
What effect will this variation in HP because of air temp changes (+/-25*) have
on the stall speed / flash of a converter?
John
Old Mar 18, 2002 | 03:52 PM
Ragtop 99's Avatar
Default Re: Effects of air temp on converter performance?
Not a lot, under a 100 rpm. Figure about a 1% change in power per 10 degree change in temp, so you are looking at less than 10 HP.
Old Mar 18, 2002 | 11:01 PM
JNorris's Avatar
Moderator
Thanks for the info.
John
