Finally Done T56 To Th400 Swap!!!
Old Feb 9, 2006 | 01:35 PM
383camaroSS's Avatar
Default Finally Done T56 To Th400 Swap!!!
I Just Got Dont Last Night Finishing My Swap From A Shitti T56 To A Th400 Street/strip!!! It Drives Incredibli Fine!! What Do You Guys Think Ill Run 1/4 Mile....i Have A 4,000 Tci T/c...4:10 Gears...150 Shot Nitrous And Headers...with 28" M/t Slick??? If Any One Has Question On A T56 To Th400 Ill Be Happy To Help On Any Part# Or Questions!!!
Old Feb 9, 2006 | 09:56 PM
CR00SS's Avatar
Hey if you could make a list of everything needed, I to am thinking of doing a t56 to th350 or th400 and using the tci flexplate and for now keeping stock torque arm. Also is your speedo working and what parts did you use. Also if you have any pics please post em`. thanks!
Old Feb 9, 2006 | 10:10 PM
cablebandit's Avatar
10s....
Crosss, i'm about to sell my whole th-400 shooting match..PM me if you are interested.
Old Feb 10, 2006 | 05:54 AM
z28convert's Avatar
I had an a4, so dunno if this is gonna be diofferent for you but my stock tq arm was mounted on the tranny and there is no spot to mount it on the th400, so i had to get a body mount tq arm with the seperate crossmember frrom spohn.
Old Feb 10, 2006 | 07:21 AM
i got a th400 crossmember with the torque arm mount on it so you can use your stock type torque arm
Old Feb 11, 2006 | 09:34 AM
JL ws-6's Avatar
Race your car!
I'm in the process of this swap myself. I have the tranny, driveshaft and converter, and a bmr trans crossmember, with the tq arm relocation. I have yet to get the tranny cooler, shifter, 6AN lines for the cooler, a trans temp guage, and I think that's it. Oh, and a bmr stock style tq arm and driveshaft loop, as I am going to remove the spohn one I am running, the ground clearance issue is driving me nuts. After that, I should have everything.
Anyone know... if I don't hook up the speedo ( as I have yet to see one that actually reads roght and isn't putting MAD mileage on the car that is false ) will the abs/tcs/cruise still work? If not, then it's all gonna come out that's fine, just wanna know.
Thanks.
Old Feb 11, 2006 | 12:20 PM
N2RACINGLS1's's Avatar
If the PCM does not know how fast you are going it is gonna be hard for all of the stuff you mentioned to work.
