will this convertor work
Old Feb 11, 2006 | 10:01 AM
GETCHA SOME's Avatar
Default will this convertor work
Sorry if this is in the wrong section. I have an fuddle 3400 2.0 str converter in my car now. My mods are hooker long tubes, through tru duals,with borla mufflers,3.73 gears, and a 150 wet shot thats hidden. I am planning on adding a secong gun around 50-75 for out the hole, mainly street. Do you think this converter is the right stall or should i change it, or just try it first. ant responses would help. thanks.
Old Feb 11, 2006 | 07:52 PM
MNR-0's Avatar
It will perform well. Personally, for NOS, I would have gone the 3200/2.0 as it will yield true torque mutliplication right up to 4000RPM. The 3400 will be a little higher at 4200RPM with a little less efficiency. If you want holding power, then a 10" unit at 3000 stall RPM might be the best bet - as you will be making killer torque off the line already.
Old Feb 11, 2006 | 08:00 PM
slimcracka's Avatar
have you ran at the track on motor with taht converter?
Old Feb 16, 2006 | 06:57 PM
yea on horsepower in cool weather 7.90's 1/8 mile, thats all we have close. Y mods are hooker headers, tru duals, converter, and gears. no lid, bellow,mass air, or throttle body work, all that is stock
