Transmedic?
Old Feb 11, 2006 | 09:36 PM
Out1aw's Avatar
Default Transmedic?
Has anyone used this product to ease a slipping gear?
Old Feb 11, 2006 | 11:12 PM
FLT's Avatar
FLT
Default Forgetaboutit!!!
You ever put a piece of bubble gum on a leaky radiator hose? Doubt it works! Which gear are you having problems with?
Old Feb 12, 2006 | 11:27 AM
Out1aw's Avatar
it slips a little into 2nd
Old Feb 12, 2006 | 12:38 PM
FLT's Avatar
FLT
Hows 4th gear? Reason I say this is because there is a band that holds in both gears. Something you can check is the 1-2 accumulator piston for cracks. This will cause poor shifts into second or even second gear starts. Kinda sounds like you need a trans. Check out FLT at www.finishlinetrans.com
Good luck!!!
DA WRENCH
