A few th350 questions
Old Mar 5, 2006 | 07:47 PM
CodeZ28's Avatar
Default A few th350 questions
Lt1 car, swapping the junk 4l60e for a th350, i know i need a spacer, i heard driveshaft will bolt directly in if the transmission is long tailshaft, i can retain stock flexplate, and supposedly I can use an internal speed sensor from a 91 92 ss chevrolet 454 truck, I also know i need a remote mount torque arm...any ideas?
Old Mar 6, 2006 | 01:34 AM
Strahley's Avatar
Well for the torque arm you have a few options
B&M makes a piece you can bolt on in between the tranny and the tailshaft that mounts the torque arm in the stock location
Or you can buy a body mounted torque arm (Jeg's has some, BMR has some, UMI has some)
I did the B&M piece and it fits wonderfully, I would reccomend that if you want to keep a stock (or stock style) torque arm
