Trans removal/Torque Conv. Install
Old Mar 6, 2006 | 10:14 PM
ss4chad's Avatar
Default Trans removal/Torque Conv. Install
I am ordering my Yank TC tommorow, how difficult is the tranny to remove? How hard is the top bolts on the tranny to get to? Besides exhaust, drive shaft, cats and Y pipe, what else has to come off? Can I use just my trusty Craftsman floor jack to safely remove the tranny with the help of a good friend? I like to think I am a desent mechanic, put my Long Tubes on by myself but never dropped a trany before. Any advice? Thanks
ps. Search doesnt work with a **** on here, tried it a couple of times!!
Old Mar 6, 2006 | 11:01 PM
smmurf86's Avatar
the top bolt was easy for me to get to if you have trouble just take the intake manifold off..if your going to use the craftmans floor jack get a piece of wood or something and put in between the two objects, more surface are for support...you have to be care when putting in the new TC there are two metal notches on the inside of the tranny that the TC has to slide into if you dont do it right when you start your car the front pump will break..it just happen to me as well. i sure you know but just in case...put trans fluid in the TC before putting it on ABout 3 quarts or so should fit in it. you have to remove 3 bolts that connects the flexplate to the TC by dropping the starter and plastic plate....after all done you might have to get a big bar to pry the tranny away from the motor sometimes it get suck on there pretty good...hope this helps.
Old Mar 7, 2006 | 01:47 AM
Blacker's Avatar
http://modernmusclecars.net/forums/a...p?do=tcinstall
Old Mar 7, 2006 | 02:43 AM
ss4chad's Avatar
RIGHT ON!! Directions!! I love directions!! Thanks guys for the help!
Old Mar 7, 2006 | 09:26 AM
1_Bad_LS1's Avatar
Those are very good directions...
I was lucky enough to have a lift to do this on, I couldnt imagine doing it lying on my back... If you have a friend that works at a dealership or something along those lines, talk to one of them, usually they have a 'hobby' night or something like that where you can bring it in for a few hours and put it on a lift...
It would make your install ALOT easier!!!
And enjoy that TC... I love my Yank SS4000
Old Mar 9, 2006 | 07:59 PM
smmurf86's Avatar
how you make out so far with the tranny drop....i am dropping mine again to put in a th350 tried to get the top bolt from under the car..was unsuccessful had to do it from up top...
Old Mar 9, 2006 | 08:59 PM
SLIKWS6's Avatar
When turning the motor, do you turn it clockwise or counterclockwise? Thanks.
How about when adding fluid to the torque converter, I take it just put the quart of fluid directly into the shaft, will this not spill out? Thanks again.
Old Mar 10, 2006 | 09:00 AM
MattDZ28's Avatar
It will not spill out unless you tilt your converter over.
Old Mar 10, 2006 | 10:04 AM
smmurf86's Avatar
i turn mine clock wise but if you go to far counter clock wise for a second wont hurt but try to keep it clock wise
Old Mar 10, 2006 | 10:49 PM
SLIKWS6's Avatar
Are all fluids the same, any recommended over others? Thanks again.
Old Mar 21, 2006 | 03:48 PM
MattDZ28's Avatar
I just want to say thanks for whoever did these directions.
Great job and you saved me money!
