Noisy Torque Converter
Old Mar 7, 2006 | 09:13 AM
surfgzr's Avatar
Default Noisy Torque Converter
Just installed a 2800 stall TC and it makes a noise when locking up (40-50mph and 4th gear). Gets even noiser if going up a hill during lockup.
Anyone else had this condition? Been told it's caused by pulse width modulation.
Any suggestions for a fix?
Thanks
Old Mar 7, 2006 | 09:24 AM
MattZ28's Avatar
What TC is it?
Old Mar 7, 2006 | 02:06 PM
surfgzr's Avatar
Originally Posted by MattZ28
What TC is it?
Fuddle. Talked to John yesterday and he had some suggestions. Still looking for inputs however.
Old Mar 7, 2006 | 03:18 PM
s346k's Avatar
sometimes when i'm at like 3/4 throttle...which is like almost 4k on the tach, the converter will decide to lock up in overdrive @ like 50 mph, which is like 1600 rpm or something...and it will squeal, i assume this is just the lock-up clutch slipping. is this what you're hearing?
yes, i know, i had the opportunity to adjust the lock-up procedure, but turned it down. i will definately look into it next time my car is getting tuned. but for the time being i just rip it to ~45 and let off the gas, so when it locks up the rpms are hardly affected.
Old Mar 7, 2006 | 07:05 PM
slimcracka's Avatar
mine kinda makes noise but it more sounds like slack in the driveterain(sp) at low speeds like 39-40 when im just crusing..
