stall/cam matching
I didnt want to go to big,but I didnt want to go to small.After doing alot of research in here and seeing all the people move up to a higher stall I just split the difference between the 4000+ people and the guys who went with what they thought was to small.
I know this reallly didnt answer your question about cam matching.I'm sure someone will chime in.
you want your stall speed to be just a hair under where your cam makes peak torque...that way when you drop the hammer the rpm shoots to (let's say 4,400 rpm) and then your car takes off ~4,400 rpm, aka peak tq. so now you are multiplying peak torque the instant your tires start rolling. which means you'll have one HELL of a launch, assuming you hook up.
Yeah, you would want a littler lower, but 2200 won't do much to wake up that engine. I would go with maybe a 3000-3200 (if that's really the total weight of the car...your swap probably made it heavier).
FWIW, I love my TCI 4000. I'm glad that I didn't go smaller. It works great even with a stock motor. It'll work even better with the F13 I'm getting later.
