need help please th350
Old Mar 10, 2006 | 04:12 PM
shackattack37's Avatar
Cool need help please th350
i got a 4l60 and want to change to th350 trans i got a 167 60ft with the 4l60 3200 Torque Converter and 373 gear what stall for the th350
Old Mar 10, 2006 | 07:57 PM
383camaroSS's Avatar
You Should Go With A 3500 To 4000 Stall..get Some Slicks For The Track And You Will Do Good In Your 60 Foot!! Is Your Th350 Manual?
Old Mar 10, 2006 | 08:21 PM
no 167 is on et drag radials
Old Mar 10, 2006 | 11:15 PM
CAT3's Avatar
Restricted User
You should get a stall based off your combo. I'm not a guru, and I know a lot ppl have excellent results with a 3500 stall. I call John Fuddle and order mine and have been happy with each one, as have my friends. Be prepared as John will ask you some details, weight, gears, tires, cam specs etc...
Old Mar 11, 2006 | 05:25 PM
SUX2BU's Avatar
we need ALOT more about your combo before anyone can suggest a converter.
Old Mar 11, 2006 | 07:53 PM
tr224 cam and pulley ported tb and i cross at 5200rpm in 1/4
Old Mar 12, 2006 | 11:17 PM
SUX2BU's Avatar
i say if your not sporaying 4400-4600
