just ordered th350 got ???
Old Mar 10, 2006 | 08:14 PM
smmurf86's Avatar
Default just ordered th350 got ???
i ordered my th350 last night from jegs.this is for a 2002 camaro. it is the one that shifts by vaccum. where do i hook up the vaccum? i guess i need the crank spacer, but can i use my stock flexplate.. what else do i need and where can i get it from...i tried searching but no luck...thanks
Old Mar 10, 2006 | 11:02 PM
Red Heartbeat's Avatar
I was thinking that if you use the stock flexplate you will either have to drill new holes or elongate the existing ones. You'll need the crankshaft spacer, it bolts between the transmission and the flywheel with new longer bolts.
Old Mar 10, 2006 | 11:11 PM
CAT3's Avatar
Restricted User
1 Shifter and cable.
2 Elongate stock flexplate holes, or safer alternative, get an SFI Approved TCI or ATI flexplate.
3 Vacuum line taps into the rear of the intake, where MAP/HVAC vacuum line is
4 TC, depending on flexplate used. Fuddle can do one for you, just gotta know if its stock flexplate and spacer, or TCI/ATI Dual Pattern Flexplate.
5 Crossmember, modify stock one or new tubular from BMR (can be had with Stock TA mounting or without a TA mount)
6 Dipstick, lokar 36" dipstick for TH350/400
7 Trans Cooler, definately.
Good luck and have fun.
