Flexplates 168 tooth or 153?
Old Mar 14, 2006 | 08:15 AM
Silver Slayer's Avatar
Default Flexplates 168 tooth or 153?
Why is there a 168 tooth and a 153 tooth flexplate for the LS1?
I found a TCI (168 tooth) and a Hughes (153 tooth). Besides the tooth pattern, what else would be the difference besides $199 compared to $129? Weight maybe?
Thanks,
Kevin
Old Mar 14, 2006 | 06:01 PM
Anyone?
Old Mar 15, 2006 | 08:12 AM
kwik_ls1's Avatar
I have a 168 tooth flex plate with my TH400 and it works fine. I am not totally sure what the difference is.
Old Mar 15, 2006 | 11:07 AM
mvonada's Avatar
Number of teeth relate to the teeth on your starter only.
Old Mar 15, 2006 | 12:06 PM
That is what I was thinking, but I have yet to see any info on a starter swap while I have been searching for tranny swap information. Does anyone have a Ls1 with a 153 tooth flywheel? As far as I know they are 168.
Old Mar 15, 2006 | 08:22 PM
SUX2BU's Avatar
i believe the 153 tooth is a SBC flywheel.
Old Mar 15, 2006 | 11:20 PM
hals73rs's Avatar
I believe the Hughes flexplate having 153 teeth is a misprint. I just used one, part #4004, in a 408/4L60E with a TCI converter and all works good. I should have counted the teeth but forgot to. I know it's the same diameter as the stock 168 flexplate.
