T56 or 4L80e
A ******* STALLED, WELL BUILT 4L80E WILL LOWER YOUR 60ft TIMES, 1/4 TIMES, etc.
In a standard you dump the clutch
In a stalled auto the computer dumps the clutch
In a standard you are using a mans skills to change gears (which can be very good shifts)
But in an auto you are using a computer to shift.
In my full manual auto I am not using the computer to shift but it has taken all the **** up shift possibilities outta the race. I tap the shifter forward, thats all. I have not been to the track and do not know much about the 60ft, but I do not have to change to 2nd gear until well over 50-60mph if that gives you an idea of the ridiculous initial pull.
https://ls1tech.com/forums/showpost....00&postcount=9
