Trans won't shift under wot.
Old Mar 15, 2006 | 10:01 AM
Xtremespeed's Avatar
Default Trans won't shift under wot.
Shifts fine around town. Hits rev limiter under wot. Won't shift until I let off. I think maybe the fluid level is low. I can't check it hot. When the car is warmed up to nomal operating temp fluid blows out of the dipstick tube when I pull the dipstick. Do you think a clogged vent could cause this? There is no metal in the pan, and the fluid looks good. Not burnt. Any ideas?
Old Mar 15, 2006 | 10:02 AM
jmm98LS1's Avatar
If it's spitting fluid out the dipstick tube, that sounds like maybe there's WAY too much fluid in there.
Old Mar 15, 2006 | 10:43 AM
I found it. The vent tube got pinched in the torque arm mount. I guess when I put the converter in.
