Fluid mixing
Old Mar 16, 2006 | 07:06 PM
Waveridr85's Avatar
Default Fluid mixing
I am planning on dropping the pan and changing the oil/gasket and filter. Can I mix synthetic trans fluid with the regualr stuff?
Old Mar 16, 2006 | 09:32 PM
Blacker's Avatar
Don't bother. Just use Dexron III and it will work just fine.
Old Mar 17, 2006 | 01:44 AM
DOUBT IT's Avatar
From what I understand, the synthetic stuff is too slippery for our transmissions. I just use the Valvoline Dexron III, and be done with it.
Old Mar 17, 2006 | 11:00 AM
camaro2you's Avatar
I am going to be changeing mine this month sometime, i picked up the valvoline dextron III
Old Mar 17, 2006 | 03:08 PM
joecar's Avatar
Synthetic Dexron III can be mixed with non-synthetic Dexron III.
But, why change only half of your trans. fluid....?
See this: https://ls1tech.com/forums/showpost....1&postcount=10
I've been using Mobil 1 synthetic Dexron III for the last 45K miles and have had no problems; non-synth D3 is still good fluid; each to his own.
Old Mar 17, 2006 | 06:50 PM
strokedls1's Avatar
I just use nonsynthetic valvoline also. The synthetic burned up my clutches too quickly.
