Need help th400 parts!!!
Old Mar 18, 2006 | 10:50 PM
n20stroker's Avatar
Default Need help th400 parts!!!
Plan on doing a m6 to th400 swap. What flexplate will i need and does any company make anything for the backup light/saftey switch.
Old Mar 19, 2006 | 10:10 AM
n20stroker's Avatar
what never done before?
Old Mar 19, 2006 | 12:11 PM
DanZ28's Avatar
Give it some time.
There is alot of good info in the sticky above as well .
Old Mar 19, 2006 | 01:26 PM
8a8mfh's Avatar
No it's just the once a week question, been asked a hundred times, been answered 100 times. Heres my answer to last weeks.
TH400, 350, 700R4, 200-4R all basically the same as far as bolting the trans to the engine and getting the flexplate to bolt up.
Old Mar 19, 2006 | 11:35 PM
b00sted's Avatar
You can use a stock flexplate and have Fuddle make you a converter that's setup to work with the ls1 and th400...Needs a different bolt pattern on the converter and a different length shaft.
