Worst time to go WOT
Good Advice.
TCC apply/release is based on the MPH vs TPS tables.
Edit: Here's a hosted image so it is more legible...
Edit: I'll go out and log data just to be sure...
IMO the only reason you should ever select your own gear is when you do a burnout in 1st. Other than that it's OD from a stop, D from a roll...
This seems to be the consensus so far, from what i've gathered from the tranny builders here. I'm no expert myself though.
Anyway, I don't think you need to tap the brakes because when you punch it to WOT the TCC unlocks anyway (there's TCC Throttle Release tables for this).
In WOT/PT downshift, the forward sprag holds when 3rd hits (engine is driving car).
In manual downshift, the overrun clutch is applied in 3rd, and...
the overrun clutch is preventing the forward sprag from overruning, which is what the sprag is trying to do (car is driving engine) before the throttle is punched; so the overrun clutch is holding back the vehicle at 70MPH (say); the overrun clutch has 2 friction plates, so I wonder if they end up getting burnt from repeatedly doing this...?
i.e. it may actually be bad to manually pull back to 3rd at freeway speeds,
but it's only the overrun clutch so engine braking is lost.
Any comments ("you're all wet, kid")...?
Now another question...is it worth doing this? Is it better to do this than just punching it from 4th?
Also i thought i read in one of the earlier post, that some one said leaving the car in OD when racing say at the track, was good, as in less chance of slipping when shifting into 3rd, is that correct?
