what is a v6 trans worth??
Old Mar 21, 2006 | 10:44 AM
Pavlock Performance's Avatar
Default what is a v6 trans worth??
wondering what a camaro/firebird v6 trans that needs to build rebuilt would be worth??
Old Mar 21, 2006 | 10:46 AM
s346k's Avatar
however much gasoline it takes to set it on fire..oh and don't forget the use of flint to actually start the fire.
Old Mar 21, 2006 | 11:04 AM
thats about what im thinking.... it's a good case but the guy who had it had a cracked radiator that mixed the water with the tranny fluid.. not good...
Old Mar 22, 2006 | 12:06 AM
Dom's Avatar
Dom
If it's 97+ then it comes with a removable bell housing. So you can change the bell housing and change the input shaft and have a V8 transmission. Internals are identical. It sounds good in theory, but there could be something else different. I don't know 100%.
