Whats STR???
Old Mar 22, 2006 | 12:34 PM
MidwayAvenue's Avatar
Question Whats STR???
What is STR and how do i know which size to go for??
thanks
Old Mar 22, 2006 | 12:58 PM
LS1 Sounds's Avatar
STR = Stall Torque Ratio
http://www.converter.cc/faq/faq.htm
Old Mar 22, 2006 | 11:16 PM
98_Formula's Avatar
str size dependson ur preference... and on ur tracction... the higher the str the more u need traction to use it. higher STR's are better for track, lower STR's are better for street (roll racing... not running slicks...)
Old Mar 23, 2006 | 01:42 AM
BlackHawk T/A's Avatar
I'll clarify on that since it was a little vague...
Higher STR is better for street driving. It helps keep the RPMs down a bit when it is engineered for the RPM range the car will be driven in.
If traction is an issue, a lower STR is usually best (for example, when racing).
Old Mar 23, 2006 | 07:20 AM
98_Formula's Avatar
^^ yea but i thought a higher STR will create more friction, which = more power loss, so for street and/or roll racing, u might lose a little, but when at the strip, u'ld more than make up for the power loss with ur ET's, traction permitting..?
