crazy vibration after shift kit install
Old Apr 8, 2002 | 09:18 AM
1/4master's Avatar
Default crazy vibration after shift kit install
the car vibrates from 2200-2400 rpm in 4th gear. the tranny shop that did the install has no idea of what this could be. is they're anybody that can help me?
PI3200 installed for a few months.
john
Old Apr 10, 2002 | 09:14 PM
Patrick G's Avatar
LS1 Tech Administrator
Default Re: crazy vibration after shift kit install
Did the tranny shop pull the driveshaft or take out the torque arm during the shift kit install?
If so, check the pinion angle first. Make sure it's between 0 and -2 degrees (nose down). If the driveshaft was taken out, try rotating it 180 degrees in the yoke. If neither was done, then let's take this to the top for some other opinions.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Apr 10, 2002 | 10:18 PM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
Could it be the Tq converter clutch shuddering when going into lockup? Hmm...
Old Apr 15, 2002 | 01:00 PM
Patrick G's Avatar
The pinion angle is the angle of the nose of the rear axle in relation to the slope of the driveshaft (driveshaft angle). If the driveshaft is sloping downward (from the motor) at a 4 degree angle and the rear pinion is sloping up toward the driveshaft and motor at a 2 degree angle...this would make you pinion angle 2 degrees nose down (in relation to the driveshaft). Ideally, you want the pinion at the same angle as the driveshaft under Wide Open Throttle (WOT). To do that often means placing the nose of the rear axle 1-2 degreess nose down. Under WOT, the flexing of the drivetrain will bring the nose parallel to the driveshaft. If your pinion angle is more than +/- 4 degrees (nose up or nose down), you can experience vibration and wear out your u-joints pretty fast. This vibration will increase with speed. Check it to be sure.
__________________
Old Apr 16, 2002 | 12:48 AM
1/4master's Avatar
thanks for the replies. i'm not sure if they pulled the drive shaft. my knowlegde of the TA driveshaft is pretty limited. so please speak newbie about this pinion angle. and i will certainly get it check out.
john
