M6 to A4 swap problems.help needed.
Old Mar 29, 2006 | 07:18 PM
JD1969's Avatar
Default M6 to A4 swap problems.help needed.
Alright so I got the trans, converter, wire harness etc. all swapped over and hooked up. The car will drive but it feels like it is slipping really bad. First gear seems non-exsistant, it almost feels like a full manual valve body car trying to take off in 2nd. I had my tuner load all the auto tables into my ECU (and yes he is good). He did say that he getting an error code on the tire size, but I don't see why this would cause it to feel like it slips or does not shift into first. Even if I manually put it first it does not feel like it's in first. If I am cruising in second and pull it down to first nothing happens, but I can feel it shift into other gears (although the shifts are very soft). Any help would be greatly appreciated.
Old Mar 30, 2006 | 06:42 PM
JD1969's Avatar
anyone??
