View Poll Results: Which one is the right choice
3800
5
29.41%
4000
7
41.18%
4200
3
17.65%
4400
2
11.76%
Voters: 17. You may not vote on this poll
Which stall for m………?
Old Mar 31, 2006 | 05:55 PM
LS1SS4ever's Avatar
Default Which stall for m………?
Which stall is suitable for 3.73 and (TSP cam 233/239) ?
Old Mar 31, 2006 | 10:07 PM
onebadz's Avatar
At least 4000 unless you plan on spraying,STR is up to you depending on how extream you want to go and what tires/suspension. Driving a TCI SSF 3500 on stock internal w/3.73 I am dying for something larger.
Old Apr 3, 2006 | 09:49 AM
LS1SS4ever's Avatar
ttt...
Old Apr 3, 2006 | 12:47 PM
mvonada's Avatar
Should look at a dyno for your car to determine peak torque and hp. A quote to help:
"Selection of the right stall speed for your vehicle should be matched to the engines peak torque; engines torque curve, and vehicle weight. In general, the desired stall speed would be 500-700 RPM below the engine RPM at peak torque. The speed allows a margin for application of the torque reserve on takeoff.
When selecting stall speed without having an accurate and precise engine peak torque rating, it is better to conservatively estimate the engine torque than it is to over estimate it. If you over estimate the torque output, the resulting stall speed will be lower than intended and is likely to make the vehicle slow off the line, increasing your ET."
Then consider what hp increases from mods are you going to have in the future. And really do your research - NOT all converters are alike
Old Apr 3, 2006 | 05:19 PM
LS1SS4ever's Avatar
Do you mean go to dyno and see my peak torque and hp after that decide which stall should I buy depend in my dyno?
Old Apr 3, 2006 | 06:26 PM
calongo_SS's Avatar
I run a custom tci 4000 with that cam, it's set up to be a little on the tight side for the bottle.
