Newb ?, What is lock vs unlocked??
Old Apr 7, 2006 | 10:20 AM
leftme4dead's Avatar
Default Newb ?, What is lock vs unlocked??
Sorry for this easy qiestion but, I hear people talking about it being locked or unlocked? Im assuming theyre referring to their converters. I dont know what it means to be locked or unlocked. Someone please correct my ignorance.
Old Apr 7, 2006 | 12:57 PM
joecar's Avatar
The torque converter ("TC") has a clutch inside it ("TCC");
the PCM can lock or unlock this clutch as it sees fit;
TCC unlocked: the TC multiplies torque and allows the engine RPM to drop less at the end of each shift (keeps engine in torque band); this improves vehicle acceleration.
TCC locked: the TC has no slip (and no torque multiplication) and transmits crank rotation directly into trans. input; this improves gas mileage and reduces heat generated by TC.
Old Apr 7, 2006 | 02:08 PM
so can any stall be locked or unlocked? if so, how do you lock or unlock a stall?
Old Apr 7, 2006 | 02:15 PM
BlackHawk T/A's Avatar
It is controlled automatically just like your stock one.
