tranny cooler install
Old Apr 14, 2002 | 07:47 AM
99lablackbird's Avatar
Default tranny cooler install
I know I have seen the same question asked before but I forgot the details. Where is the best place to mount the tranny cooler? If I remember correct it was in front of the condenser? If so how the heck can I mount the 19000 GVW in front of this?
Isn't the top cooler line on the 99TA the return line?
Thanks for any input guys?
Old Apr 15, 2002 | 11:02 PM
Ed Blown Vert's Avatar
Default Re: tranny cooler install
I mounted my 24K in front on the condenser using the pull-ties. Lines were pointed down.
And yes, the top line is the return line. Should be the same on the T/A
<small>[ April 15, 2002, 11:06 PM: Message edited by: Ed Z28 Convert ]</small>
Old Apr 16, 2002 | 12:10 AM
DanZ28's Avatar
Ditto what Ed said. I mounted mine on the drivers side as the fan sits lower on that side and is easier to mount with the long ties. Forget about ever mounting an FTRA now though..
Dan
Old Apr 17, 2002 | 07:04 AM
OBSSSD's Avatar
https://ls1tech.com/ubb/cgi-bin/ulti...;f=24;t=000640
