bolting trans crossmember to floor
Old Apr 11, 2006 | 04:44 PM
GrahamHill's Avatar
Default bolting trans crossmember to floor
The goons who have previously owned my car also owned whatever is in the floor thats holds threads for X-member bolts on my transmission.
So what am I gonna have to do to replace whatever was there? Replace floor section? Some sort of insert? Just make my own tabs with nuts on them....?
Old Apr 12, 2006 | 12:34 PM
GrahamHill's Avatar
bump for the hump....
.... day
Old Apr 12, 2006 | 02:16 PM
Steve Burger's Avatar
LS1TECH Sponsor
Did you try a tap?
Old Apr 13, 2006 | 11:05 AM
GrahamHill's Avatar
It feels like its pulled the threads out. Taps correct a bur but I dont know about this situation. Maybe step up a size in threads?
Old Apr 13, 2006 | 03:26 PM
koolaid_kid's Avatar
You could go with a larger bolt, or you could put a rethread in. They make them for folk who strip out there spark plug holes, seems it would work for your app as well. The name of the part escapes me, but surely someone here knows what they are called.
Old Apr 13, 2006 | 03:39 PM
Z'mnypit's Avatar
Helicoil or insert them. Drill the hole out a tad larger, insert helicoil/insert. Then add new bolts. Ive had to helicoil a ton of parts on my car. I swap **** to much......
Old Apr 13, 2006 | 06:18 PM
GrahamHill's Avatar
lol
Thanks fellas!
Old Apr 14, 2006 | 10:35 AM
GrahamHill's Avatar
Whats the threadsize on the factory bolts?
